1992 Ford Explorer cranking but not starting
974,500 MILES • 6 CYL • 4WD • AUTOMATIC
FEEBLYHURTINGU
so today i did the fuel pump on my car figuring that that was the problem when i didn't hear the fuel pump kick on or click or anything. but two hours later and with a new fuel pump it is still not starting. i checked the relays and fuses. i don't know what else could be causeing this? maybe the coil pack? i cheaked for spark...... no spark. but why wouldn't the fuel pump be kicking on?
Dec 10, 2007 at 10:09 AM
T-MAN
  • 9 POSTS
relay is bad,or pcm bad...only 2 possible...most likely since you stated no fire from coil pack,computer is toast
Feb 16, 2008 at 10:07 PM
