1992 Ford Explorer cranking but not starting
FEEBLYHURTINGU
  • 1992 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 974,500 MILES
So today I did the fuel pump on my car figuring that that was the problem when I didn't hear the fuel pump kick on or click or anything. But two hours later and with a new fuel pump it is still not starting. I checked the relays and fuses. I don't know what else could be causeing this? Maybe the coil pack? I cheaked for spark. No spark. But why wouldn't the fuel pump be kicking on?
Monday, December 10th, 2007 AT 6:09 PM
T-MAN
  • 9 POSTS
Relay is bad, or pcm bad. Only 2 possible. Most likely since you stated no fire from coil pack, computer is toast
Sunday, February 17th, 2008 AT 6:07 AM
