1992 Ford Explorer Trans Fluid Loss
BRYANDL72
BOB andKEN Ihave a 1992 explorer it is losing transmission fluid not on ground or cant see no leaks every 2or3 weeks I add just started couple months ago and now will not lock in 4wheel drive it shifts and no slipping yet can you please tell me where fluid is going or what might be problem with it? appreciate very much for some advice
thaks
bryan
Apr 14, 2007 at 5:05 PM
MERLIN2021
  • 17,250 POSTS
If the tranny cooler lines go to the radiator...check the radiator for contamination. Other than that, if the tranny has a vacuum modulator you could be sending it out the tailpipe! Look under the vehclie...any wet areas behind the tranny?
Apr 15, 2007 at 2:09 AM
Suggested Repair
If the transmission cooler lines run to the radiator, check the radiator for transmission-fluid contamination. Also check whether a vacuum modulator is sending fluid out the exhaust, and inspect under the vehicle for wet areas behind the transmission.
Conversation Summary
The owner of a 1992 Ford Explorer reports losing transmission fluid every two or three weeks with no visible ground leak. The Explorer still shifts without slipping, but it will not lock into four-wheel drive. The expert suggests checking the radiator for contamination if the cooler lines go there, checking a vacuum modulator that could send fluid out the tailpipe, and looking under the vehicle for wet areas behind the transmission.
