1991 Ford Explorer TRANSMISSION ISSUES
89,900 MILES • 6 CYL • 2WD • AUTOMATIC
RATKILLER10
WHY WHEN I PUT INTO DRIVE,TAKES COUPLE MINUTES TO ENGAGE AND GO.............WHAT IS CAUSE/CURE.....................
Feb 14, 2010 at 7:36 AM
  • 110,248 POSTS
THe most common cause is age. The seals and o-rings in the trans get hard and allow fluid to bypass them. As a result, it takes a few seconds to engage. I would recommend having the trans serviced and a good additive added to help soften seals and o-rings. THere are many available.
Let me know if it helps.
Feb 14, 2010 at 3:25 PM
