1991 Ford Explorer tranny swap question
THEROBBINS41406
  • 1991 FORD EXPLORER
  • 6 CYL
  • 142,000 MILES
My 2 wheel drive explorer has a a4ld transmission, can I use a 4 heel drive transmission and just swap the nose from my 2 wheel drive to the 4 wheel drive transmission without changing the output shafts?
Monday, March 15th, 2010 AT 7:09 PM
  • 109,779 POSTS
We recommend staying with direct fit parts because there are always differences. Will it work? Chances are it would, but you would have to check everything to make sure it is the same when making the change.
Monday, March 15th, 2010 AT 10:07 PM
