Transmission problem
1991 Ford Explorer 6 cyl Two Wheel Drive Automatic
Truck was pulling but had a bad transmission leak from seal. So i change the seal and torque converter while it was down but now it wont shift into any gear... I've check fluids, shift cables. Wont move an inch now... Transmission yolk turns for a min then stops..
May 19, 2010 at 5:37 PM
