1991 Ford Explorer Not enough heat
JOANNADAWN
Heater problem
1991 Ford Explorer 6 cyl Four Wheel Drive Automatic
We have the vehicle for almost two years. This is the second winter. Depending on the temp is how warm you stay inside. Actually you can not keep warm at all in the cab. Right now it is below zero and you can't even keep the windows defrosted let alone get warm in there. It barely blows any air through the vents. How or what do we do to fix the problem?
Nov 18, 2009 at 4:39 PM
  • 75,988 POSTS
Try replacing the thermostat and see what happens
Nov 18, 2009 at 6:07 PM
