my tranny is shifting too slow the fluid was burnt and overfilled so i changed it and added trick shift synthetic. when i first start out it needs some gas before it will go into gear but i think that means the fluid change caused the torque converter to leak into tranny that started after change. the slow shifting comes and goes when i first start out it shifts normally then as it heats up it shifts slower and slower but not everyday some days it is normal??? could it be a sensor or computer? also sometimes but rarely it will feel like im in neutral when i am in drive at a stoplight on a hill it reminds me of a manual but if i give it gas it goes into gear? because this stuff comes and goes i dont want to swap tranny if its just a sensor or something.
Nov 6, 2009 at 2:44 AM
