1991 Ford Explorer leak
1991 FORD EXPLORER
122,000 MILES • 6 CYL • 4WD • AUTOMATIC
JULIEFRASIER
i have a leak somewhere above the oil pan. someone said it could be where the 4 wheel drive meets. i hope i am explaining this right. can i do away with the 4 wheel drive and the problem will go away. the transmission is good in the vehicle, but it has this leak. i was told that where the leak is has 4 bolts attatched. if confusing i will ask again and resend a better question.
Feb 16, 2010 at 11:23 AM
  • 110,240 POSTS
Hi:
There is a seal that is between the transfer case and the transmission. I believe that is where you are describing. If it is leaking, you need to replace the seal. As far as removing the transfercase (4wd) you can't do that.
Feb 17, 2010 at 12:41 AM
