1991 Ford Explorer Ignigation Coil
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
ODONOVAN
My igniaton coil needs to be replaced, will this fix the cylindors that are missisng?
Mar 19, 2009 at 8:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If one of the coil packs is faulty then that will definitely cause a misfire yes..but I can not tell you for sure if that is the only issue you are having which is causing your misfire problems..
Thanks for using 2CarPros.com!
Mar 19, 2009 at 10:02 AM
