1991 Ford Explorer fuel lines
ABEAR69
Smells problem
1991 Ford Explorer 6 cyl Four Wheel Drive Automatic
yes i need to know how to replace the fuel lines on my 1991 ford explorer and exactly where they are located
Apr 12, 2009 at 12:44 AM
BILLYMAC
  • 2,204 POSTS
hi if you are changeing the fuel line on the engine.
they are under the plantum.on top of the engine
if you mean the lines under the truck they connect at the engine and run down under the mastercylinder where they connect at the fuel filter.from there they run back to the tank along the drivers side frame rail.to replace these the fuel tank will need to be removed. billymac
Apr 12, 2009 at 1:08 PM
