1991 Ford Explorer Engine oil in water
215,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVID TAYLOR
Loosing coolant and oil, but there is oil in the coolant. The exhaust is steam with a smell of oil in it
Jan 14, 2010 at 4:27 AM
  • 110,248 POSTS
It sounds like a bad head gasket. Perform a compression test to check for lower compression in a cylender. Here is a how to:
https://www.2carpros.com/dia/how_to_check_compression.htm
I wish I had better news, but based on your description, it sounds like a head gasket to me in every way.
Let me know what you find.
Jan 14, 2010 at 12:16 PM
