1991 Ford Explorer Chirping Noise
20,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHRISTINATE
  • 23 POSTS
I just got my truck out of the shop, they put a new alternator in. When I started it, it sounded like there were a whole nest of birds chirping under my hood. I took it back and they said it must be the alternator (it was used). They said they replaced it (I don't think they did) and it was still chirping. Then a couple of days later, I blew a cylinder on my back wheel. When they had it up on the lifters, they said they sprayed some lube and found that the chirping noise was coming fom my water pump and it was going out. Could that be true or am I getting shafted? Because my truck never made that noise until it went in to the shop for the alternator. Thanks!
Jan 16, 2009 at 3:19 AM
  • 110,248 POSTS
Hi:
Check something for me. Take a small cup of water to the vehicle. Open the hood, start the car, and slowly pour a small amount of water on the belt. Keep in mind it may splash back at you, so protect your eyes. Let me know if the sound changed or went away for a short amount of time.
As far as the wheel cylender blowing out, that can happen.
Positive feedback is appreciated.
Jan 16, 2009 at 4:49 AM
CHRISTINATE
  • 23 POSTS
[quote:d636fcec42="Jacobandnickolas"]Hi:
Positive feedback is appreciated.[/quote:d636fcec42]
I will do it when I get home into the heated garage....The wind chill is -17. Thanks!
Jan 16, 2009 at 5:55 AM
CHRISTINATE
  • 23 POSTS
We put the water on the belt and it instantly stopped. But after about 20 seconds, it started again.
Jan 16, 2009 at 12:28 PM
KEVIN12881
  • 336 POSTS
belt dressing or new belt..keep eye on temp for the water pump though
Jan 16, 2009 at 12:41 PM
