1991 Ford Explorer Calipers
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
WDAUPHIN
How do you remove front calipers
Jul 6, 2008 at 6:37 AM
BLACKOP555
  • 10,386 POSTS
use a c-clamp to compress them if the caliper is locked up.
if not remove the retaining bolt/clips and pull it off, then compress it with a old brake shoe and a c clam. then you can continue on with your brake routine.
dont hang the caliper unsupported by its hose.
Jul 6, 2008 at 1:20 PM
