1991 Ford Explorer burnt tranny fluid
DAYZ
  • 1991 FORD EXPLORER
Transmission problem
1991 Ford Explorer 6 cyl Two Wheel Drive Automatic
it started with first time. Blew the seals. Replaced. Within one week. Blew seals again. (Front pump seal). Replaced. This time. The output shaft seal. And the fluid is burnt. What! Thank you.
thank you Mark. ;-)
Saturday, August 9th, 2008 AT 1:34 AM
  • 31,937 POSTS
Hi there,
I would be concerned about the burnt oil, this a sign of slippage causing the transmission to over heat, this with a possible blocked breather will cause the transmission to overpressure and blow out a seal, I would be getting the transmission serviced and inspected for component damage before it fails.
Mark (mhpautos)
Saturday, August 9th, 2008 AT 2:34 AM
