1991 Ford Explorer battery cables getting hot
MATTHEWSCHOFIELD
  • 1991 FORD EXPLORER
  • 6 CYL
  • 114,856 MILES
My battery cables are getting hot. I changed the starter and the battery but the car still won't start. Now the battery cables are getting hot. What is causing this and why won't it start?
Thursday, April 9th, 2009 AT 2:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty voltage regulator. Voltage regulator is integral with the alternator. Replacement of the alternator is required if regulator has failed.
Thanks for using 2CarPros. Com!
Thursday, April 9th, 2009 AT 2:27 PM
MATTHEWSCHOFIELD
Thank you I will try that and let you know if it worked
Thursday, April 9th, 2009 AT 6:19 PM
