HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Electrical
Alternator
Replace/Remove
1991 Ford Explorer alternator
MARIA CALDERA
MEMBER
1991 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
10,000 MILES
How to change the alternator by myself?
Saturday, August 2nd, 2008 AT 1:14 PM
JOE HENRY
MEMBER
Detach the neg terminal of battery, unplug the connectors, take off the serpentine belt, undo the bolts. It's an easy job. But remember how the belt goes back on. Draw a pic if you do not still have the diagram under the hood.
SPONSORED LINKS
Wednesday, August 6th, 2008 AT 12:11 AM
Please
login
or
register
to post a reply.
Related Alternator Replace/Remove Content
How To Change The Alternator
Is It Difficult To Change The Alternator Ona Ford Explorer? I Used To Do Work On My Cars But Today Cas A Bit Difficult To Get Around, But...
Asked by
mariob539
1 IMAGE
2004
FORD EXPLORER
VIDEO
Alternator Replacement
Instructional repair video
GUIDE
Got a red battery warning light on? This most likely means the alternator has gone out and needs a replacement. To confirm the failure use a voltmeter to test the alternator...
Alternator Not Working?
I Changed The Alternator Thinking The First One Was Defective And Knowing The Second Could Not Be Defective Yet It's Still Not Putting...
Asked by
irt312
1 ANSWER
8 IMAGES
1997
FORD EXPLORER
1999 Ford Explorer Alternator Replacement
1999 Ford Explorer 4.0 Sohc V6 Auto 4x4 120k The Alternator In My Explorer Is Bad, I Got A Quote From A Local Mechanic For 487$ I Am...
Asked by
rongsays
1999
FORD EXPLORER
2003 Ford Explorer Altenator Replacement
Engine Mechanical Problem 2003 Ford Explorer 6 Cyl Four Wheel Drive Automatic How Do You Replace The Altenator
Asked by
brutis53
1 ANSWER
2003
FORD EXPLORER
2003 Ford Explorer Alternator Replacement
How Do I Replace The Alternator On A 2003 Ford Explorer?
Asked by
abrischler
1 ANSWER
2003
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Online car repair manuals
