1991 Ford Explorer 4x4
FORDMAN707
Electrical problem
1991 Ford Explorer 6 cyl Four Wheel Drive Manual
for some reason when ever i try to push the 4x4 button nothing happens.and yes, i push it while driving at a normal speed,and no lights, no nothing. i don't know, i would really apriciate some feed back.
Feb 8, 2010 at 1:13 PM
  • 110,251 POSTS
I need you to check if the 4wd actuator on the transfer case is getting power when you push the button for 4wd. Chances are the actuator on the transfer case has gone bad.
Let me know what you find.
Feb 11, 2010 at 4:39 AM
