1991 Ford Explorer
RAYTAY
Brakes problem
1991 Ford Explorer 6 cyl Four Wheel Drive Automatic
my brakes will not work. one big problem i can not get the piston on the brake calipers tomove when i press the brakes. fluid will come out of the line when not connected to the caliper.
Aug 31, 2009 at 6:02 AM
  • 110,248 POSTS
Do you have 4 wheel disc brakes? If so and the piston doesn't move, chances are the caliper needs replaced.
Sep 1, 2009 at 6:42 AM
