1991 Ford Explorer
MARCIANO
1991 Ford Explorer
my wheel is leaning on the passenger side. do I have to change the wheel bearings or the upper and lower bearings?
Apr 5, 2009 at 4:28 AM
  • 110,248 POSTS
If the wheel is leaning, a simple alignment could take care of the problem. The tilt you refer to is called wheel camber. It is an adjustable item with an alignment. This doesn't mean there are no worn parts. Just that there may be an alignment problem.
Also, if you have a wheel bearing that is that bad, you would hear it and it would almost be impossible to drive the car. Have all steering components checked when the alignment is done.
If you have other questions, let me know.
Apr 8, 2009 at 6:39 AM
