1990 Ford Explorer fuel pump relay
123,000 MILES • 6 CYL • 4WD • MANUAL
JLCHAFIN
Vehicle has been setting for a while. Problem: no power to fuel pump; fuse is good. Haynes manual shows relay located in power distribution box but there are no relays, only fuses. Also it shows the location of the box on the opposite side of the engine compartment. My fuse box is located on the passenger side @ fender well. My question is: where is the fuel pump relay located exactly?
Jan 19, 2008 at 7:31 AM
T-MAN
  • 9 POSTS
[quote:dbc1455d3e="jlchafin"]Electrical problem
1990 Ford Explorer 6 cyl Four Wheel Drive Manual 123000 miles
Vehicle has been setting for a while. Problem: no power to fuel pump; fuse is good. Haynes manual shows relay located in power distribution box but there are no relays, only fuses. Also it shows the location of the box on the opposite side of the engine compartment. My fuse box is located on the passenger side @ fender well. My question is: where is the fuel pump relay located exactly?[/quote:dbc1455d3e]
relay is underneath fuse panel on fenderwell.unplug wire connector on left coming from fuse box,pull fuse box up(retainer clips are between box and fender well)...under fuse box is another box,pull it up(3 relays attached to it from underneath,fuel relay is one closest to firewall)...relay is 12 bucks at autozone
Feb 16, 2008 at 9:19 PM
