1985 Ford Explorer Rear axle bearings
127,000 MILES • 6 CYL • 4WD • MANUAL
AKACARLOS
I want to remove the rear axles and replace the bearings and seals. Thanks
May 10, 2010 at 9:20 AM
  • 110,248 POSTS
This is a very involved job. I recommend getting a good repair manual with step by step instructions and pictures to identify parts. Actually, this job should be left to a qualified service technician as it requires the rear differential to be disassembled. Unless you feel comfortable doing it.
Also, I am assuming this is a 95 because they didn't make the explorer in 85. For me to try to explaine this via the internet allows too much room for error.
May 10, 2010 at 1:58 PM
AKACARLOS
thanks for the answer.I do feel like i can do it and have pulled the diff cover and while it was draining, went and got the parts. By the time I got what i wanted, brake shoes, wheel cylinder, wheel bearing and seal, I ran out of daylight and had to make dinner.
If you have any input I would appreciate it. But I do have a question and that is, since I have not pulled the axle yet, I wonder if the inner race of the bearing is a machined surface on the axle itself as I could not find a inner race for sale at the store. and it is a roller bearing and not tapered. Thanks
May 10, 2010 at 3:41 PM
  • 110,248 POSTS
I believe it is.
May 10, 2010 at 11:37 PM
