Will not turn over/crank
191,234 MILES • 4.6L • 4 CYL • 2WD • AUTOMATIC
TERIA91
My truck was broken into by someone I know and they have cut the wires by the fuse and relay box. antifreeze was leaking on my passenger side because I bought a can for my A/C and he cut it open, but I cannot figure anything out. Everything under the hood looks good but it will not start.. can anyone help? Please and thank you in advance.
Aug 13, 2017 at 9:40 AM
STEVE W.
  • 15,421 POSTS
Did you repair all the cut wiring, and check to see if there were other cut wires?
Check the fuses as well, and depending on how the wires were cut it may have damaged the Powertrain Control Module or the instrument panel. Both of those need to function correctly or the engine won't run.
I would also try a security reset as it may have tripped the system and cut power to the fuel/ignition system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
After that you would need to check for spark and fuel to determine which is missing.
Aug 15, 2017 at 5:47 AM
