windshield fluid washer pump
FORD EXPEDITION
BP827
  • 8 POSTS
2000 Expedition, 115,000mi, 4.6L.
My front windshield fluid was not being pumped when I depressed the switch. The rear worked. Then I went to the fluid holder and move around the part that attaches to the bottom of the reservoir and ... the front worked but now the rear works off and on ... mostly off. What might the problem be? Thanks, Brian
Nov 5, 2007 at 7:41 AM
MERLIN2021
  • 17,250 POSTS
Unplug the connector and check the pins, one or more could be loose or corroded!
Nov 5, 2007 at 8:35 AM
BP827
  • 8 POSTS
How do I "unplug the connector"? Thanks for your help. Brian
Nov 5, 2007 at 10:17 PM
