Engine swap
SGS1
at 250,000 miles the engine in my SUV let go and am replacing it with a 1999 Navigator engine will it fit?
Mar 27, 2007 at 2:02 AM
MERLIN2021
  • 17,250 POSTS
Same engine...
Mar 27, 2007 at 7:02 AM
FORDTECH1
  • 23 POSTS
I think the navagator uses the 32 valve engine. I don't know if anybodys tried that yet.
Mar 27, 2007 at 11:57 AM
JAREDR1025
It is not the same engine. it's totally different and will not work.
Oct 18, 2019 at 5:54 AM
Thanks for the info. This post was 12 years old so I am sure they either figured that out or made it work. Either way appreciate you weighing in.
For the record this can be made to work but to your point, the time and expense makes it not worth it and probably should not be done due to how different they are.
Thanks again.
Oct 18, 2019 at 9:04 AM
