No fuel
JAMMINCOOT
I have a 1999 ford expedition with the 5.4L It's not starting. I shot a little ether in the air intake and it fired. All the relays fuses are ok. Then I pulled and tested the fuel pump and its working
May 19, 2007 at 9:51 PM
  • 75,988 POSTS
[quote:71fd8d9446="jammincoot"]I have a 1999 ford expedition with the 5.4L It's not starting. I shot a little ether in the air intake and it fired. All the relays fuses are ok. Then I pulled and tested the fuel pump and its working[/quote:71fd8d9446]
Did you check the fuel pressure?
May 19, 2007 at 10:13 PM
JAMMINCOOT
no i didn't the injecters were replaced about 3\months ago
May 20, 2007 at 1:10 AM
