2007 Ford Expedition
JBDELGADO
  • 15 POSTS
2007 Ford Expedition V8 Two Wheel Drive Automatic
When decelerating and braking at almost a stop the car will buck and jerk forward. Any advice on how to correct this.
Aug 30, 2010 at 4:01 AM
  • 110,248 POSTS
Does it feel like an engine, brake, or a transmission issue?
Sep 16, 2010 at 1:49 AM
JBDELGADO
  • 15 POSTS
I think transmission because i see no jump in RPM's gage.
Oct 15, 2010 at 3:44 AM
  • 110,248 POSTS
The only thing I can think is the trans isn't disengaging properly (almost like a manual transmission if the clutch isn't used). Have any warning lights come on?
Oct 15, 2010 at 6:19 AM
JBDELGADO
  • 15 POSTS
No warning lights. It does not happen often but when it does I notice it. What should i emphasize to the dealer ship when i take it there since I am expecting the problem not to present itself while they are checking it.
Oct 15, 2010 at 10:48 PM
  • 110,248 POSTS
It sounds like a solenoid or the torque converter.
Oct 16, 2010 at 2:50 PM
JBDELGADO
  • 15 POSTS
Is it possible for me to replace either of those parts without having to go to the dealership? If so how....
Jan 4, 2011 at 8:51 AM
  • 110,248 POSTS
Actually, you need to have the trans pressure checked for the converter. They would have to do it. If the converter itself is bad, the trans needs to be removed.
Jan 4, 2011 at 11:16 AM
JBDELGADO
  • 15 POSTS
Ok, what about the solenoid, could i replace that and if the problem reappears take it in then?
Jan 4, 2011 at 11:25 AM
  • 110,248 POSTS
I think it is about a 50 dollar part, plus you need to remove the trans pan, fluid... That is up to you. I have attached a picture of where it is located on the valve body. I found a good picture on the net that should be helpful. It is the round item at the top of the pink section.
Jan 4, 2011 at 3:22 PM
