2007 Ford Expedition
66,700 MILES • V8 • 2WD • AUTOMATIC
JBDELGADO
  • 15 POSTS
What is checked/cleaned when a tune up is performed by ford that will make the cost of my tune up 350 dollars.
Aug 30, 2010 at 3:58 AM
  • 110,248 POSTS
That sounds like something only that dealer does. Have you asked them to describe what it is?
Sep 16, 2010 at 1:52 AM
JBDELGADO
  • 15 POSTS
They said that it is because its a 3-valve engine. That they clean the actual valves. What exactly should a tune up include besides new spark plugs/wires.
Oct 15, 2010 at 3:51 AM
  • 110,248 POSTS
That doesn't sound right to me. To clean the "valves" either they ran a cleaner through the engine which should be no where new that price, or the had to remove the heads to clean them which is not part of a tune up and would be much more expensive.
Honestly, on your vehicle, there really isn't much to a tune up. Plugs (wires if it doesn't have a coil pack for each cylender) air filter if needed, PCV valve, Fuel filter... Unlike the old days, you don't have a distributor cap, rotor...
Oct 15, 2010 at 6:28 AM
JBDELGADO
  • 15 POSTS
Thanks. Instead of the actual dealership is there any other nation-wide auto care places you would recommend for just a basic tune-up.
Oct 15, 2010 at 10:51 PM
  • 110,248 POSTS
I'm not allowed to recommend because then people think we get paid from them, and we don't. Any of the nationally recognized shops are usually good. However, if you want, I can try to direct you as to how to do it. If you don't feel comfortable, before the shop you pick does anything, let me know what they tell you. I have no interest other than helping you. Therefore, I will be honest.
You let me know and take care of yourself.
Oct 16, 2010 at 2:56 PM
JBDELGADO
  • 15 POSTS
I would like to do it myself in that way I could continue to do it in the future by myself.
Jan 4, 2011 at 5:10 AM
  • 110,248 POSTS
Basically, all they are going to do is replace spark plugs. Each cylender has one. At the top of the valve cover is a coil pack for each spark plug. Remove one coil pack at a time and then, carefully, remove the spark plug which is down in the valve cover.
When you get the new plugs at the parts store, have them show you how to gap them and what the gap should be. It is easy to do, but will take 2 pages to explaine how.
Replace the plug, reinstall the coil pack making sure the rubber boot snaps on to the new plug and replace the coil pack bolt. It is tight in the rear of the engine, so be careful not to break a plug when removing it.
Let me know if you run into trouble. Also, check the air filter and you may want to consider replacing the fuel filter.
Jan 4, 2011 at 8:36 AM
JBDELGADO
  • 15 POSTS
For the coil packs, are they screwed on, or do I just pop them out? should I unplug them before I remove them from the cabling?
Jan 18, 2011 at 4:38 AM
  • 110,248 POSTS
There is one bolt that holds them in place. Remove the wiring first, then the bolt, then they will pull out.
Jan 18, 2011 at 10:06 AM
JBDELGADO
  • 15 POSTS
Is there any amount of time I should let the engine cool down before I start. Also is there anything I could add the make the removal easier like carb cleaner spray?
Feb 25, 2011 at 3:14 AM
  • 110,248 POSTS
Allow the engine to cool down completely so you don't get burned on anything. As far as coil removal, if you feel it's needed, use a penetrating oil on the one bolt that holds the coil on. Something like WD40 or PB Blaster will help the bolt come out easier.
Feb 25, 2011 at 4:28 AM
JBDELGADO
  • 15 POSTS
Thanks for the quick response, I actually meant if there was anything I could add to make the removal of the actual spark plug easier to turn out.
Feb 25, 2011 at 4:33 AM
  • 110,248 POSTS
Sorry about that. The only thing I can tell you is to be careful not to break them. As you already know, there has been a problem with removal. There is a special tool that has been made. I haven't had a need for it yet, so I can't say that I have seen one. It it's a 100+ dollar tool, so I'll get it when I need it. As far as spraying anything, same thing. Any penetrating oil can't hurt. Just try to clean the area out once the plug is removed.
Feb 25, 2011 at 4:37 AM
JBDELGADO
  • 15 POSTS
Thanks, so do i need that special tool or can I just take out the plug with a spark plug socket?
Feb 25, 2011 at 4:39 AM
  • 110,248 POSTS
You should be able to just pull it out, but they have had issues with the plugs breaking. Just be careful.
Feb 25, 2011 at 5:18 AM
JBDELGADO
  • 15 POSTS
Thanks for the response, I have to admit I am a bit confused. I figured that after I removed the coil packs I would have to use a socket wrench to "twist" the spark plug loose from the engine and then take it out. Are you saying that they are suppose to "pop" out after I remove the coil packs? Thanks again.
Feb 25, 2011 at 5:22 AM
