2006 Ford Expedition The battle of the expedtion!!!!!!!!!
2006 FORD EXPEDITION
XXBBLISSFULXX
Shakes or Wobbles problem
2006 Ford Expedition V8 Two Wheel Drive Automatic 113 th miles
have a 2006 ford expedition. it has 113 thousand miles on it. The car itself when up to high speeds runs and shifts perfect. changed the coils and plugs.tranny fluid, oil changed got the cadillac converter check and its fine... u joints are fine... the sypmotoms of the car are... idle is fine... but when comeing from a stop and going around 30mph the cars rpms go up and down up and down... then the car starts to heavyly vibrate (sometimes mild) it is almost as if you are riding on the side of the interstate on the ridges that are their to keep truck drivers alarmed, but after i let off the gas it goes away and i drive it normal untill i go slow speeds again.. when you dog it everything is fine.. tranny shifts fine perfect. just when going slow speed... it makes a loud hummm and vibration... i could have swore this was a u joint connected to drive shaft.. but went to the repair shop and he says they are fine.... i feel like if i get on it and go fast from get go it doesnt happen at all, and i can drive it and manupilate it to not vibrate. sometimes that works, i really need to figure out the problem... do you think it could be the torque converter? or something wrong with the tranny thank you soo much
_lyndsey
Jul 31, 2010 at 5:04 AM
  • 110,244 POSTS
The noise you hear, does it change with speed? Also, does it change when making turns?
Aug 4, 2010 at 11:06 AM
