2006 Ford Expedition Steering Wheel Vibration
30,000 MILES • V8 • 4WD • AUTOMATIC
JOBECK5
My steering wheel is vibrating at hwy speed, the higher the speed, the worse the vibration. It also vibrates sometimes when I brake. What could be causing this, and should my warranty cover it?
Thanks!
Jun 15, 2009 at 12:57 PM
  • 110,248 POSTS
It could be caused by tire ballance or a bent rim. Try rotating the tires to see if it changes. Also, when you use the brakes and it shakes tells me your front brake rotors are warped.
Jun 18, 2009 at 4:53 PM
