2006 Ford Expedition code
101,000 MILES • V8 • 2WD • AUTOMATIC
BUG61
I have a code P2104,P2111,what does it mean how can I fix it
May 27, 2009 at 9:16 AM
JIS001
  • 3,412 POSTS
Codes are for electronic throttle problem? Could be a problem in the circuit, binding throttle plate, the throttle itself or probplems with the pcm. You will need to have diagnose and it wouldnt hurt to call Ford and see if they have some sort of extended warranty on the electronic throttle should that need to be replaced?
Jun 4, 2009 at 1:00 PM
