2006 Ford Expedition Air conditioning
2006 FORD EXPEDITION
70,000 MILES • V8 • 4WD • AUTOMATIC
ARMYGIRLVET
2006 Ford Expedition XLT 70,000 miles. After driving the vehicle for a couple of hours today in 90 degree heat, I stopped at home then went out to leave again. Started up the vehicle and then steam starting blowing out from under the vehicle at the back end. At the same time, I noticed that a light yellow oily fluid was leaking from under the front end of the vehicle. My husband thinks it could be something with the air conditioner. Any ideas?
May 18, 2008 at 12:09 PM
  • 31,937 POSTS
Hi there,
You may have a coolant teak in the engine, check level and if low get a pressure test asap to help locate fault, before you do more damage.
Mark (mhpautos)
May 18, 2008 at 3:36 PM
