2005 Ford Expedition tire sizes
42,000 MILES • V8 • 4WD • AUTOMATIC
IMAKCOLD
I'm looking at upgrading from a 1997 expedition to 2005 expedition. I've got new tires [not wheels] on the 1997, they are LT2857017R. The 2005 calls for and has P2657017R on now. Can I swap the LT285's to the 2005 . Also should'nt the 2005 already have LT'S on it.
Jan 30, 2010 at 8:47 AM
  • 110,248 POSTS
First, please understand that we recommend only what the manufacturer recommends. If that is an optional size, then great. However, if not, I can't recommend it. I will tell you it will fit the rim and shouldn't be a problem. In reality, there isn't much difference. As far as the LT rating, the vehicle is still considered a passanger vehicle and not a truck. However, I own one and the upgrade to the LT is a good choice. It has a heaver sidewall and will last longer on the truck.
Again, the tires shouldn't be a problem, but I can't make that recommendation. Just make sure they don't rub. I hope you understand.
If you have other questions, let me know.
Feb 1, 2010 at 2:41 AM
