Electrical problem
2005 Ford Expedition V8 Two Wheel Drive Automatic
Every time ignition is turned to start enginge the 30 amp starter solenoid fuse blows. I have replaced the starter. it still blew fuse could it possibly be weak battery causing all this trouble? when the small wire going to the starter from the fuse panel is removed from the starter the fuse does not blow.
thanks frank
thanks frank
Feb 21, 2009 at 2:13 AM
