i have a 2005 ford expedition and the ac my truck is not working anymore it blows hot air. a couple of they ago the ac was working fine but then i check to see if it need more 134a i look like it need a little and i added a full cand but after i added the can and after a while a burst sound and it smell like the gas came out but the air was working fine i didn't do anything to it after but it was not cooling like it was before. two days i go i check the gages and it need some 134a so i added another cand and ti was working fine but when i took it for a ride the i head the same bursting noise and then hot air was coming out it check the motor and it was not running and then i try to check the gages but it did not let pulg the house the valve. can you tell me what happen or what can i do to fixed it or what else can i check.
Jun 16, 2008 at 8:47 AM
