ac blowing hot air?
2005 FORD EXPEDITION
JGMATA36
i have a 2005 ford expedition and the ac my truck is not working anymore it blows hot air. a couple of they ago the ac was working fine but then i check to see if it need more 134a i look like it need a little and i added a full cand but after i added the can and after a while a burst sound and it smell like the gas came out but the air was working fine i didn't do anything to it after but it was not cooling like it was before. two days i go i check the gages and it need some 134a so i added another cand and ti was working fine but when i took it for a ride the i head the same bursting noise and then hot air was coming out it check the motor and it was not running and then i try to check the gages but it did not let pulg the house the valve. can you tell me what happen or what can i do to fixed it or what else can i check.
Jun 16, 2008 at 3:47 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
To ill an A/C system correctly, you need a manifold gauge set so you can see the pressures in the system, to me it sounds like you added too much, and the relief valve opened and vented the R-134a to the atomsphere. This also sounds like the compressor has gone out or the system is low on charge or a fuse is bad, these videos and guides can help us fix the problem with diagrams below to show you how on your car. I have included (below) the air conditioner wiring diagrams as well so you can see how the system works.
https://youtu.be/4UjfQKvrB6Y not working
and
https://youtu.be/uZrQCGwXfek recharge
and
https://youtu.be/yrhWKlQEPWw leak detection
and
https://youtu.be/4EqdrBVb0sY vacuum and recharge
and
Let us know what happens and please upload pictures or videos of the problem.
Jun 16, 2008 at 3:56 PM
JGMATA36
It was the high pressure valve on the compressor, I got a new one and installed it to fix the problem. Thanks for the guides.
Jun 16, 2008 at 4:03 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
nice work use 2Carpros anytime.
Jun 16, 2008 at 4:09 PM
