Side Mirror replacement?
NMORRIS
How do I replace the side mirror on the passenger side of my 2004 Ford Expedition Eddie Bauer edition?
It has remote adjust, heated and turn signal built into the mirror housing. Are there any special tools required to replace the complete housing and mirror?
Dec 14, 2008 at 10:57 PM
DAVE H
  • 13,383 POSTS
Let me know if you need any of the diagrams ?
Exterior Mirror
Removal and Installation
NOTE:Do not remove the exterior mirror assembly when repairing an individual part. Individual components can be installed without removing the exterior mirror.
Remove the front door trim panel. For additional information, refer to INTERIOR TRIM AND ORNAMENTATION .
Position aside the weather shield.
Disconnect the exterior mirror electrical connector.
Fig. 38: Disconnecting Exterior Mirror Electrical Connector
Courtesy of FORD MOTOR CO.
Remove the exterior mirror.
Remove the nuts.
Fig. 39: Removing Exterior Mirror
To install, reverse the removal procedure.
Install top nut first.
Exterior Mirror Motor
Remove the mirror glass. For additional information, refer to EXTERIOR MIRROR GLASS .
Remove the three exterior mirror motor screws and exterior mirror motor.
Disconnect the electrical connectors.
Fig. 40: Removing Exterior Mirror Motor Screws And Exterior Mirror Motor
Exterior Mirror Glass
Position the exterior mirror glass in a downward position to obtain a gap at the edge of the mirror.
Fig. 41: Positioning Exterior Mirror Glass
WARNING:Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in the instance of glass breakage.
Fig. 42: Disengaging Mirror Glass
Disengage the mirror glass.
Insert a flat-blade screwdriver between the mirror glass tabs and the mounting plate, and rotate to separate the locking tabs from the mounting plate.
Carefully pull the top edge of the glass away from the exterior mirror housing.
If equipped, disconnect the heated mirror electrical connectors and remove the glass.
Fig. 43: Disconnecting Heated Mirror Electrical Connectors And Removing Glass
Rotate the exterior mirror glass in all directions after the installation to make sure all clips are completely attached.
Exterior Mirror Cover
Release the four retaining tabs and remove the exterior mirror cover.
Release the vertical tabs first.
The two outboard vertical tabs are released by moving them in the outboard direction. The two inboard horizontal tabs are released by moving them in the downward direction.
Fig. 44: Releasing Retaining Tabs And Removing Exterior Mirror Cover
Rotate the exterior mirror glass in all directions after installation to make sure all clips are completely attached.
Dec 14, 2008 at 11:05 PM
CMESWME
I have a 2003 Ford Expedition / Eddie Bauer. The right side view mirror always adjusts itself to the full upward tilt position. Also, the controller to adjust both mirrors does not work. I manually adjust the mirror, but when I turn the vehicle off, then back on, the mirror goes back to the upward tilt position. Any ideas ? Thanks.
Jul 21, 2020 at 6:57 AM (Merged)
WRENCHTECH
  • 20,758 POSTS
If you have a driver preference system for seat and steering wheel position that coulsd be part of that system and pre-programmed to a certain driver position. If you have controls for driver one and driver two try either changing the setting or using a different key.
PIXIEDUCK
Need instruction on removing inside driver side door panel in order to replace drivers side mirror
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1324.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_397.jpg
LEELEWIS
Mirro and wiring fell from windshield, is it advisable and can I fix it myself at home?
  • 110,251 POSTS
They make a repair kit. Basically, you clean and prep the glass and reglue the mirror back on. It takes about 10 minutes. Just go to a parts store and ask for a rear view mirror repair kit.
ROYCAR71
  • 359 POSTS
I removed mirror glass head to install arrow light indicators. Do I have to brake out glass to have more leverage to push back glass surface with groove onto ball? Very hard to ball back groove.
  • 55,851 POSTS
Yes those can be difficult to get back in. Did it fall out? You must align each one of the pegs into the holes, I don't think you should remove the glass.
Cheers, Ken
ROYCAR71
  • 359 POSTS
I fix it back. I cut piece 4x4 wood about height of frame and put towel over mirror depressed gently with clamp. Later when I had to do again for other side I found I could do it with hand.
Jul 21, 2020 at 6:58 AM (Merged)
  • 55,851 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
