replacing Front brake pads
NEWSROBLES
I am replacing the front brake pads, I am having trouble removing the caliper mounting bolts, am I supposed to use a wrench or a Allen wrench? I tried a socket wrench, but could not find the correct size, i notice what seems to be a allen wrench hole in the middle of bolt head, but tried several sizes of allen wrench... Thanks for any assistance
Dec 1, 2007 at 5:00 AM
MERLIN2021
  • 17,250 POSTS
Here is a guide to help you do the front brakes
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Try a TORX T-40 or 45 to remove the caliper. here is how you bleed the brake once you are done.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Dec 1, 2007 at 5:31 AM
JMINOR87
my question- when changing the brake pads on the expo. am i also going to have to change the brake fluid as well?... or can i jus change the pads and that be the end of it?
Oct 27, 2018 at 9:49 AM (Merged)
ZACKMAN
  • 4,202 POSTS
Optional on fluid. Recommended but not required.
RHOLANDO
  • 17 POSTS
Hi ,
I had my front break pad replaced for sometime now on a ford expedition 2000 xlt , but recently I'm experiencing a slight vibration or rumbling sound when ever i step on my break running on 70 kph, i can feel the vibration almost at the middle underneath the engine. i think the sound is progressive. anything i should directly look at? Thanks.
Roland
  • 31,937 POSTS
Did you get the rotors machined? can you feel this in the steering or brake pedal?
RHOLANDO
  • 17 POSTS
i think the brake pedal i feel the slight vibration when i press the break all the way. it doesnt show ang jiggle or any sort it breaks normally it just has this slight vibration like grinding during break press. it wasnt there before so im think it has something to do with the latest replacement of my breakpad several months ago. steering is fine.
