2004 Ford Expedition Leak in front differential
2004 FORD EXPEDITION
74,000 MILES • V8 • 4WD • AUTOMATIC
MAR200
Need to replace seal in front differential. How is this done? Also, truck making a roaring noise in front noise gets louder and quieter when speed of vehicle changes.
Jul 14, 2010 at 2:15 AM
  • 110,244 POSTS
Is it a pinion seal or axle seal? Also, if you hear a noise, you may have to take things apart to see if the bearing in the differential is bad. A bad bearing may be what caused the seal to go bad.
Jul 15, 2010 at 4:07 PM
