2004 Ford Expedition Check Air Suspension
94,000 MILES • V8 • 4WD • AUTOMATIC
KIM052870
In the Message Center of my car the "check air suspension" light came on. The car is sitting very low...is there someway to reset the suspension myself. If so..how?
Jul 7, 2010 at 9:56 AM
  • 110,248 POSTS
If it sitting very low, then either there is a major leak, the compressor is bad, or it isn't getting power. Can you hear the compressor run when you first turn on the key? If not, have you checked all fuses?
Jul 7, 2010 at 3:55 PM
KIM052870
[quote:2a49f08f12="Jacobandnickolas"]If it sitting very low, then either there is a major leak, the compressor is bad, or it isn't getting power. Can you hear the compressor run when you first turn on the key? If not, have you checked all fuses?
Joe[/quote:2a49f08f12]
It sounds normal to me...We did however check the fuses, everything looks fine in that department. Something about being able to reset it manually, know anything about that?
Jul 9, 2010 at 6:01 AM
  • 110,248 POSTS
Nothing about a reset, but there is a switch to turn it on and off. It must be turned off when the vehicle is lifted.
Jul 9, 2010 at 5:54 PM
