bled the brakes and ABS light is on and stays on
2004 FORD EXPEDITION
12,000 MILES • V8 • 2WD • AUTOMATIC
FAST944
replaced rear rotors and brake pads but the rotors would not come off. so i had to take the whole hub off to end up getting them off. I finish the whole job, ABS sensors were put on and they were not dirty and bled the brakes and ABS light is on and stays on. what could it be? let me know, thanks.
Feb 28, 2010 at 11:59 AM
We need to start with checking for codes. I attached some guides that will help with pulling ABS codes.
https://youtu.be/rTtAnsOlZU4
Once we get the codes, I am sure we will confirm a wheel speed sensor issue so we will need to run through this guide on how to test and replace them:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Clearly at this point we are assuming at this point so let's start with checking the codes and we can go from there. Thanks
Dec 1, 2020 at 4:00 AM
