2004 Ford Expedition 2 Questions
111,500 MILES • V8 • 4WD • AUTOMATIC
MAURO08036
1st- rear wiper doesn't work. Motor good. Where is rear wiper control module.
2nd- blower only blows on high. where is relay
Nov 22, 2009 at 10:11 AM
  • 75,988 POSTS
Hi Mauro08036, and TY for the donation Answer to no.1 ? Check and test fuse no.1 10 amp and fuse no.38 25amp, also test the rear wiper motor relay in the liftgate rear motor wiper assembly.
https://images.2carpros.com/forum/automotive_pictures/12900_wiper_2.jpg
For no.2 The blower motor resistor controls the speed of the blower motor its located behind the center of dash.
https://images.2carpros.com/forum/automotive_pictures/12900_blower_motor_resistor_14.jpg
Nov 22, 2009 at 11:14 AM
MAURO08036
#1- fuses are good and I install new motor. Still nothing. Rear washer doesn't work either.
#2- can you send a larger verison of both diagrams because I can not see at all? Is resistor easy to get to?
Nov 22, 2009 at 9:57 PM
MAURO08036
Nov 22, 2009 at 10:06 PM
  • 75,988 POSTS
Disregard what you've seen when you came back its not your answer. Give me your email addy and I'll try to buff it up.
BTW it sounds like the microprocessor is defective which is located within the liftgate rear motor wiper assembly.
Nov 23, 2009 at 3:30 AM
MAURO08036
email:nickcolin@verizon.net
I put a new motor assy in and still nothing. What about the switch?
Please send diagram on blower and rear wiper
Thanks a bunch!!!!
Nov 23, 2009 at 5:59 AM
  • 75,988 POSTS
Just sent it, should be in the inbox-Let me know
Nov 23, 2009 at 7:53 AM
