2003 ford expedition wont start and makes a buzzing noise from under the dash, It has 80000 miles and is the big V8
Nov 4, 2007 at 11:17 AM
Confirm the battery is charged and the terminals are clean, and try a jump start first. Use the original key and lock and unlock the doors with the remote. Try starting in Neutral, then check the under-hood relays and the starter.
The owner of a 2003 Ford Expedition V8 with 80,000 miles reports that it will not start and makes a buzzing noise under the dash. The expert recommends verifying the original key and remote lock/unlock, checking battery charge or jump starting, trying Neutral, and inspecting the under-hood relays and starter. Another owner reports the same symptom, and the expert again prioritizes the battery, terminals, a jump start, and the starter.
