2003 Ford Expedition Sensor says running lean and has a hes
120,000 MILES • V8 • 4WD • AUTOMATIC
RFLAT
My check engine light came on and I had it checked. The code said that my engine was running lean. At the same time the front AC stopped blowing and the car picked up a bad hesitation, not sure if these are related. The hesitation does not happen all of the time, just randomly. We could hear a vaccum leak coming from the elbow hose at the pcv valve. Changed that hose, but it didn't fix the problem. I also changed the mass air flow sensor, but it did not help either. After I changed these parts out I took it back and had the code cleared. It showed back up the next day and read the same thing. Running lean. Thanks for your help.
Oct 8, 2009 at 1:44 AM
OBXAUTOMEDIC
  • 3,713 POSTS
Here is a link to check out it will give you info on lean mixture codes for both bank 1 and/or bank 2.
https://www.2carpros.com/first_things/why_does_my_engine_have_a_lean_mixture_code.htm
Oct 8, 2009 at 2:02 AM
RFLAT
Actually hooked it up to the computer again last night and it said cylinder number 3 was misfiring in first 1000 rpm's. Any ideas on what could be causing it? Thanks.
Oct 9, 2009 at 1:17 AM
OBXAUTOMEDIC
  • 3,713 POSTS
Here is something to try...
Swap the #3 coil with another one and see if the Misfire moves to that cylinder if so replace the coil and boot.
Oct 9, 2009 at 1:17 PM
