2003 Ford Expedition Headlamp Replacement
55,000 MILES • V8 • 4WD • AUTOMATIC
SMCCAUSLAND1964
I had the low beam lamp go out and thought it would be as easy to replace as the lamps in my 05 Taurus. Wrong. I am mpretty savy but am stumped on this one. Please clue me in on how to take care of what should be a pretty simple repair.
Feb 15, 2009 at 2:31 AM
MIKE H R
  • 3,094 POSTS
under the hood is 2 headlight housing retaining clips for each side, push them back, then you can pull the headlight housing out and away from the vehicle, to access the bulb there is a retaining ring rotate the bulb retaining ring counterclockwise, you should be able to get to the headlight bulb. make sure you do not touch the new bulb with your bare fingers reinstall the new one.
Feb 19, 2009 at 1:14 AM
