2003 Ford Expedition Grinding or howling noise
158,000 MILES • 6 CYL • AWD • AUTOMATIC
NICENSMILEY
My car makes a howling or grinding noise if I am going up a hill. But it doesn't do it all the time. If I am at a steady 50 mpg going up hill it may not make the noise. If I press on the gas then it might make it. Almost a whistlling/howling sound. Yet, sometimes it happens when I am going 5 mpg on a flat surface if I lightly tap the accelator. It's very confusing. And sometimes when I'm on the freeway going 60-70 mpg it will make it. That one seems more frequent. Any guesses as to what the problem is? I would say it has gotten worse over the past month or so.
Jun 29, 2010 at 5:47 AM
  • 110,248 POSTS
Have you checed the fluids in the differentials and transfer case? Can you tell if the noise is in the front or rear?
Jul 2, 2010 at 1:55 PM
