2003 Ford Expedition fuel filter
2003 FORD EXPEDITION
97,000 MILES • V8 • 2WD • AUTOMATIC
JTJCMOTT
where can i locate the fuel filter on this 2003 under the hood or along the frame
Jun 18, 2009 at 1:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your fuel filter is located on the inside of drivers side frame rail, close to tank. Use a flat blade tool to turn the filter protective cover tabs 45 degrees, then remove the cover. Disconnect filter fittings and remove filter.
Jun 18, 2009 at 1:29 PM
