My drives a 2003 Expedition and after drove extremly low on fuel more times than one. A day ago she said that it it started stuttering and shut off while drive, but started right back. up. When i check it out she had put some gas in it but i seen that the oil was extremly low. The truck idles fine but then starts to stutter and rev back up suddenly then almosts turn off just to restart and do it somemore. right before it stall i can hear sound of air or puff's or somthing right before it turn off. what is it? last time had a simailar problem and it turn out to be a coil pack was bad.is this the case again or problem from running low on oil. the oil pressure was fine.
Nov 25, 2008 at 9:46 AM
