2003 Ford Expedition Air Conditioning not working
YHERNANDEZ22
  • 2003 FORD EXPEDITION
  • V8
  • 85,000 MILES
I recently had freon put into my air conditioning. It worked great for about two weeks, but than went completely out. Will not get cold whatsoever. What could be the problem?
Saturday, June 19th, 2010 AT 10:48 PM
  • 109,885 POSTS
Is the ac compressor still cycling?
Tuesday, June 22nd, 2010 AT 7:29 PM
YHERNANDEZ22
Yes, it still is
Friday, June 25th, 2010 AT 11:34 AM
  • 109,885 POSTS
If it is cycling, the system is working. I need you to check what is called the blend air door. It is located near the heater core. In one direction, it allows heat into the car and the other, it allows AC. If it is stuck or not working, you won't get cold air.
Saturday, June 26th, 2010 AT 1:32 AM
