2003 Ford Expedition A/C vents
DANANDLINDA
  • 2003 FORD EXPEDITION
Air Conditioning problem
2003 Ford Expedition V8 All Wheel Drive Automatic
A/C vents close when under a load.
Wednesday, July 15th, 2009 AT 2:19 PM
  • 109,885 POSTS
The vents are run by vacuum. When you accelerate, the vacuum drops in the engine which is causing the vents to close. You have a vacuum leak. CHeck under the dash and under the hood. With the engine running, you may actually be able to hear a hissing sound that would indicate a leak, but a vacuum leak is what you are looking for.
Thursday, July 16th, 2009 AT 10:43 PM
